Hole in the boot - whats the best way to fix it?
Hi there,
I have a hole in my boot that is letting in moisture, I'm not sure it's letting in water as such as there is not a pool of water, but the area is very damp and it is making the back seat damp. Here is a picture below..
post-915652-0-55662100-1394737043_thumb.
Any advice on the best way to fix this?
Is it better to try and fill the area in, if so what is the best substance to use?
Or is it better to use some kind of plug to fill the hole and then fill around that? Maybe the plug itself would do it?
Here is a picture of the other side where the area is still intact...
post-915652-0-66368900-1394737052_thumb.
I should mention the car is a 2002 Polo S 1.2.
  • Replies 9
  • Views 1k
id find a bung that fits then plenty of seam sealer both sides , something like tiger seal sealer
Thanks I may try that this weekend.
I suppose I can get a rubber bung from any hardware store, just needs to fit this hole.
You might want to sand any rust off and cover in hammerite before fitting the bung and sealer so the hole wont get any worse over time...
Good shout, thanks for the advice.
That plug was probably pushed out because the boots was filling with water,,
Try rear lenses sunroof drains rear was wipe tubes.....
What was that last bit? Wipe tubes, what's that?
Rear screen washer pipe work
Yeah sory all the pipework for the rear wash wipe,the pipe can split and spray water all over.
Ok thanks I will take a look.
