Urgent help needed :(
Might be wrong section... But I've got a huge crack in my windscreen that's come from nowhere, rang auto glass and they wanted 300 for a replacement...
So I was thinking of doing it myself or seeing if anyone know cheaper places
Cheers john
  • Views 463
Try and get it done with your insurance policy first. I take it you dont already have windowscreen cover in place in that case try adding it to your policy but dont say your've got a crack. Your policy should go up a couple quid each month but'll be cheaper in the long run. Then ring up a couple weeks later and get it replaced for £75
Failing that try get a windowscreen from a vw breakers and autoglass etc will just charge you a fitting fee. As the actual glass is the expensive part.
Lastly try national windowscreens and some other local windowscreen companys.
Edited by polo-trigger
A friend of mine has a company his garage use... 100 they come out and fit a new window while I work... seems easiest tbh and a good price as I dont have the cover... cheers for the help
