6n2 Door
My polo 6n2 drivers side door won't open from the inside. I either have to put the window down and let myself out that way or get a mate to let me out, and it doesn't look good. Anyone had this or recognise what it is? Snapped cable?
  • Views 533
First Welcome to the forum.
It will either be a snapped cable or the handle has snapped off the cable attachment bit
Cheers. I will have a look tomorrow then if it's easy to look. How do I go about getting the door card off with regards to the wires to the electric window switch?
The switch panel will come out of the door panel with a small screwdriver under the edges and gently pulling up, then you can get at the plugs for the switches
I'll look tomorrow, thanks a lot!!
