Fighting Rust - Help
The shell on my car is fairly straight with minimal rust. However I'm going to respray it my self so obviously want to remove any rust currently present.
Just wondering about the best was to do this so that the rust doesn't come back (at least for a while)
I will be sanding the car down but was planning on leaving the original paint but sand it for a good key so I'm mainly thinking what chemicals are out there as google has given me a good variation of products and methods but not really a definitive as to what really works
  • Views 679
total removal is the only way it will last
so sand blasting , wire wheeling or something like bilt hamber deox gel , and in some cases a combo of those
then an epoxy primer on the bare metal, no probs going over the sound orignal paintwork
Edited by steveo3002
Yeah that's what I was thinking, it's mainly my boot seem and where there so a hole in the drivers floor,
I didn't know if I could clean off the rust round the outside of the seem then blast it with something to get at any rust between where the seems meet, re prime and spray it or if honest is a better method to prevent seem rust.
its its along a seem youre going want to get as much rust out as poss prime it, seam seal it then paint you just need to get some grey scotch to key up the old paint
