07 polo dials help please
Hi. Iam new to this site and would appreciate any help you can give. How do you remove the dials on my 2007 polo? I simply want to take the bulb out for the airbag warning light! I have removed the 2 torque screws from the bottom and cant see anything else holding it in yet it still wont come out ha is it just me being daft?!?
  • Views 1.2k
First welcome to the forum.
The airbag light is'nt a straight forward bulb removal!! it is a surface mounted LED that will need unsoldering, and removing it will mean an MOT fail!! as the light has to come ON then go out after a few seconds.
To remove the speedo you just undo the two torx screws at the bottom of the unit and then it will pull out of the dash
Hi mate thanks for reply i got told that my car will fail with the air bag light constantly on? so basicaly i have to take it to garage to get it sorted? :/
Yes That's a fail as well, you need to get it connected to VCDS and fix/erase the fault code
