air bag light wont turn off
Hey Guys !
I have a polo 6n2 1.4 16v valve on a Y reg
I bought a brand new Momo Team steering wheel fits perfect and the horn works i fitted the small fuse to the Air bag wiring inside the wheel and still the light stays on. it turns off when the car is started then after 2 seconds it comes back on!!!!
Any guidance on permanently turning it off would be much appreciated ??? .
  • Views 1.2k
Two possibilities, there is a fault code logged in the airbag ecu when you disconnected the airbag unit, or the resistor/fuse is the wrong value and has set a fault code! either way you'll need to get it onto VCDS/Vagcom to erase the code/s
oooo rite many thanks ! ill give it a go.....
Or just put the right wheel for car normally the best way don't forget smile if eva the worst happend you wish your air bag was there then :)
