Polo 6n2 window
Heard this is a common problem in polo 6n2 and also lupos of the same era. Electric window switch doesn't work on drivers side and can only control the passenger side window coming upwards. Can anyone help me with regards to parts and cost?
  • Views 714
Iv got the same problem on my gti... just stopped one day... gonna just buy a whole new block for it... probs only cheap on ebay... if that dont work its a wire issue
Window switches get water in and common as.
You really should never assume eBay is cheaper. ALWAYS try dealer first in my opinion. For reasons such as:
eBay second hand window switch console (so 2 switches and lock/unlock switch in housing) £60
1x window switch brand new from VW £17...
I know which if prefer seen as you could spend said £60 on a second hand one that stops working almost straight away
You are looking at few possible faults, the drivers window control, 1- window control switch 2- window motor control unit, Unable to control passengers window 1- window control switch, 2- wiring defect probably in the flexy rubber tube between the door (drivers or passengers) and the bodyshell, As Matt has said the switches are quite cheap from VW and at least you know your buying a working item rather than chancing an ebay sale item!!
