My first car!
So picked up my first car, and it was the exact thing I wanted!!
Polo 2002, 1.4 TDI. 120k, so quite high but is a diesel eh. Got 6 months tax, and MOT till October.
Pretty happy with it! Paid £1050, bit higher than I wanted because i'm not good at hagaling because i'm only 18 but still not bad I think! :tongue:
But first things I am going to do is use a bit of T cut to get some scratches out of the paint work, and change the timing belt as i'm not sure when it was done last. I'll check the MOT/log book etc (not actually got the car yet getting it at 5, but went for a test drive and handed over the money and got the keys)
But yeah i'm stoked! Any heads up? Things to look out for?
  • Views 731
You got it for a steal to be fair as they usually go for £2000-2500 even with that sort of mileage!
As long as these are well serviced and use the correct pd oil you shouldn't see many problems. Cambelts are due every 60,000 miles or 3 years whichever comes first (used to be 6years but got changed use to premature snapping) so defo get it done ASAP if it is overdue.
Make sure the turbo isn't noisey as it could be a sign of it on its way out, and make sure the pedal box is good
Other then that enjoy!
Cracking price!!
120k isn't high by today's standards at all!
Awesome, well its got full serivce history, all stamped and only 2 previous owners! (previous girl had it for less than 8 months)
Going to get the timing belt done yeah, just wondering, is there a good place to get parts? LIke genuine apart from dealer?
Will probably do the water pump and tensioner at the same time. Plus an oil service, filter the works! But yeah any good website any one know of for genuine or good qulaity parts?
Bargain, although the 9n tdi's are a little less sort after than 6n2. 120k is just running in.
I would always buy genuine parts especially belt and pump. Peddle boxes are not a common fault on diesels, gearboxes on the tdi can be.
I've be advised gates do good belts and pumps, and decent price for £120 too so went with that kit.
Whats a good quality oil and filter to get? Friend works in a car shop so will just ask him to get it on a slight discount :P
bekts, thought these were chains?
Nah that's the 1.2 petrols that are chain!
