9n3 2006 need wiring diagram help Elec windoww
Hi,
I'm having this on going problem with the electric windows both passenger and driver windows will not go up and down. I have checked the switch and door handle switch with no result. I have also did manage to get the windows moving but as soon as I take the key out and try again it stop working (I got it to work by removing the fuse). I have also bought a working driver side motor with module, I plugged it in and nothing still the same. Now I'm looking at the comfort electric control module can this have any interaction with the controls of the electric windows?
Does anyone have the pin outs for the driver side electric windows motor 6Y1959801
also pin outs for the comfort control module?
I'll see if I can use a probe to power the electric windows circuit.
Edited by POLO9N32014
  • Views 4.1k
Popular Days
Update this morning I have now installed the new motor and reinstalled the door card as you would know the problem still there. However I have movement but i had to remove a 25 amp fuse (it's the 25 amp fuse above 10 amp) --> img0678q.jpg
and with the probe i had to supply positive 12v. The wired thing is is that now the left switch operates the driver window. Does anyone know if this fuse feed power to the comfort control module?
