Clear pipe to filler neck arch hole
Sorry for the random subject but I don't know how to describe it in short. Basically the problem is this, I changed my fuel tank the other day and when reconnecting the clear pipe that runs from the top of the tank, through the arch and connects to the filler neck, I noticed that where it runs through the arch, the hole is a little larger than the pipe, therefore allowing water to come through and into the car.
Can anyone recommend a way to cover this? Is there a product you can use or do I have to design some kind of stop?
Thanks and any help appreciated?
Conrad
  • Views 592
the pipe that runs to the top of the tank?
it should run inside a metal tube , if its rusted away then a welded repair would the best way forward , otherwise depending on how bad it is , you could clean it up and use polyureathane sealant or some fibre glass paste
Yeah the tube has rusted away. Will go and get some sealant. Thanks for the tip
If it rusted away.. The wheel arch isn't the only way in, when the tank is down you can see the other end.. Will also let the weather in, ending up on the inside of your rear 1/4 and sill.
Remove and old rust and treat bare metal. Then run a pipe as a replacment for the metal old one, seal that in on both ends then run the clear breather pipe inside that.
Try putting a Hoover down your rear 1/4 to pick up what was the metal old tube, you'll be suprised/disgusted what you can fish out!
