Air roof stuck shut, although the motor is trying to open
My sons Polo a 6N2 with air roof, has had someone stick a knife through the soft top. It has let in water and the roof does not now open, although you can hear the motor start what ever locks the roof in place is not opening so the motor can not open it. I need to open the roof slightly so I can remove it and replace it with a new one. any suggestions. Thanks in advance Tony
  • Views 1k
First Welcome to the forum.
If you pop the cover off the motor/roof light, there should be a manual handle so you can wind the roof back
Thanks for the info, I did find the tool and tried winding it, it winds tighter to close but just unscrews if you wind it the opposite way, I take it I am doing something wrong, is there another hole to wind open or what do you do to wind open?
I will try that in the morning when its light. Thanks for this really helping.
Re check my previous post I've put a link to an answer last month
