Glove box problem
My car didn't originally have a glove box so I bought one off eBay and tried to install it. The door goes on fine but I'm having trouble screwing the catch onto the dash. the hole in the dash is far bigger than the screw that comes with the catch. Has anyone else had this problem? Any ideas on how I can fix it? I didn't really want to glue it but I tried to glue it and it just fell off. :(
Here is where the catch screws in but as you can see the hole is much bigger than the screw:
  • Views 1.3k
Looks like it's been butchered to give a bit of adjustment, but that screw is intended to go into a captive nut and not just screw into the plastic
Right so there is a nut missing? And i butchered it because I tried to plastic weld the hole up with a soldering iron so I could drill a new smaller hole but the dash plastic doesn't melt very well so it didn't work.
As you can see on this diagram there is a clip nut #20
post-36925-0-11483800-1397284455_thumb.p
pin - hinge
cap for catch
satin black
sealing bearing
fillister hd. bolt / shorten to:
M4X20 15MM /
snap nut
3,1X16,5X11 /
Ah yes there is, thanks for the diagram. Any idea where I could get one of those clips?
I'd imagine they are still available from VW/TPS if not try one of our sponsors VW Herritage?
Yeah I'll try that, cheers dude! :)
