Door lock issues!
Hi all, I've got a slight issue with a front door on the Mrs' Polo 6N
Once the car has been locked and unlocked (has central locking, non remote) the interior handle will not open the door. The exterior handle will open it on the second pull.
Once the door has been opened, the exterior handle works on the first pull, and the interior handle also works.
This is very consistent, but recently both handles have started refusing to work at all once the car has been locked and unlocked.
Any ideas as to what it might be?
Thanks in advance.
  • Views 681
Also, can I swap the door locks between the front and back doors?
I know the fronts have key locks, and the backs have kiddy locks, but are they ancillaries or whole units?
something does not make sense here. remove door card and see what's happening.
from interior door handle, there should be metal wire which pulls on the mechanism to open the door.
also when you have your key in the lock and turn, does it feel klunky?
You can buy replacement spring and barrel from VW for around £20. But if the lock is feeling smooth then it isn't that.
The key moves as it should in the lock, and operates the central locking fine. I took the door card off this morning, the vaccume for the central locking works fine, the metal rods are secure and free moving, and nothing looks out of place.
It seems really odd, I'm starting to think a trip to the breakers is in order... :/
