2000 Polo GTI indicator problem
Hi,
I have recently bought a 2000 Polo GTI and have joined the forum to hopefully solve a little niggly problem on my car.
It has a strange problem with the indicators, the flash rate slows down as i drive. It starts off at a normal rate, then the more i use the indicators, the slower it gets. I have changed the fuse and all 6 bulbs but it has not fixed the problem.
I was wondering if anybody has experienced this problem or knows any possible cause.
Any ideas/suggestions would be greatly appreciated
  • Views 2.5k
the switch could be faulty, or the controller which is built into the hazard light switch, this appears to be problematic from what i have read.
Thanks for this. I'll try the controller first as i am going to change the stereo anyway, so i guess i could do both at the same time.
when the radio is out, it can be removed from behind, it just clips in.
Excellent. Two jobs in one! thanks for the help
Hi,
Just an update on the indicator problem. I can confirm that it was the relay. Bought a used one on ebay, removed the radio and center panel in the dash and like Dixy says, it just clipped in. Problem solved :)
