smoothed rear door handles (mot)
Looking into smoothing my 6n's rear door handles to give it a nicer look. Just wanted to know would it pass an mot like this?
  • Replies 12
  • Views 3.2k
  • thats right- eric you got it the wrong way around. after market steering wheels SHOULD fail. the fact many still pass is up for debate
no.
I failed an mot last year due to the fact the 2013 regulations state you must be able to open the rear door from the inside and outside.
i didnt have smoothed handles- just a broken lock which made it inoperable
must add- it did work from the inside
if that is the case, then why are cars allowed to have child locks fitted? surely that would go against it wouldnt it?
Going by what it says on that site. If the control isn't there to open the door then it can't fail. If u wanted to install a popper then that would get around it, however it also says any airbags obviously missing will fail what about all the after market steering wheels none of them fail. I work in a garage and the front doors have to open from out side and inside rear doors only have to open from inside. Obviously child lock is allowed but a car using child lock wouldn't tend to be modified to the point it's had it rear doors smoothed.
The manual states
Doors
1. Open and close the driver’s and passenger’s
doors. Check that:
a. each door latches securely in the closed
position
b. the driver’s and front passenger doors can
be opened from both inside and outside the
vehicle
c. any other passenger doors can be opened
from outside the vehicle.
C. Was the 2013 ammendment
So in answer to Erics question chld locks are not applicable as the rear doors only need to be opened from the outside
sweet so i can carry on stealing children legally! happy days. :diablo:
if an airbag isnt fitted then it cant be tested. if a steering wheel is fitted that doesnt have an airbag, it will not have the SRS emblem on it, and thus cant be tested, if it had the emblem and no bag = no pass.
as for the light on the dash, it should be out , but if there are no airbags then its advisory.
at least thats how i have been doing it :)
as for rear handles, personally i would fail it, if it had an electric switch somewhere i would advise that it should have a label and be visible and accessible from outside the car - which isnt very likely.
personally i think its a silly idea, but thats my opinion.
just think of it this way, if someone was stuck in the back and needed to be taken out quickly and couldnt because there are no handles and they die, could you justify it because " it looked cool"? :) ...okay its a bit drastic but it makes a point
have you thought about using different handles? i have always liked the fiat barchetta handles. they would look awesome on all four doors.
If that's the case why do 3dr cars pass mot? That's why rear door handles haven't been a failure as for it coming up now as a failure is a load of rubbish as long as It can be opened from inside then that's all that counts in my eyes.
yer - forget the rules and the law- just do what counts in your eyes
does this also cover the rear hatch, which can be classed as a door?
Not a passenger door though.
