Noisy steering wheel issue
Hi all,
I have swapped out the air bag coil connector slip ring which has fixed dash air bag warning light. However the replacement part (used)is making a grinding noise, what can I do to silence the sucker.(other than turn the tunes up)
IE can I use grease, if so what part should I be greasing and what kind of grease should be used or avoided?
thanks in advance
Kevin
  • Views 677
could be the cowling isnt on right, try moving it as you turn the wheel. shouldnt need greasing at all, but if you do then dont use copper grease as it will make your horn go off all the time.
Thanks for the reply dixy, I'll take another look at it.
