whats the easiest qnd cleanest way to get thr bump strips off my polo?
Hi I have bought my polo a while ago but one of the bump strips on the door of tge car has started to fall off and therefore I want to take them all off. Thrre is a glue like thing that was holding it on before, I would just like to know whats the best way to remove that without scratching the paintwork
warm em with a heat gun or hair dryer and then use fishing line to slice under the molding
then clean off the mess with a toffee wheel or panel wipe on a rag
I found a thread after I posted this that said use warm water one then slowly peel them off and it worked so well, you have to scrub a little bit of a sticky resedue after it but its fine.
The dick who owned tbe car befofe me tried to glue on the bump strip back on and its left of a bitch of a resude that I haven't been able to get it off yet though.
So if anyone knows a good way to make this glue like stuff come off id love to know
Petrol soaked rag and an old credit card to scrape it off or as mentioned before a "Toffee wheel"
id not suggest anyone peel them off...I've seen the doors ripple where the tape is so strong , plus it will bend the trim so less chance of re using it if you change your mind later
no but I was doing it that day and I found something on the internet that said use warm water to get them off, and it worked really really well. they have been removed and I got rid off all residue left by the strips, the only one left is that fucking glue that some nobhead put on my car. this guy must of been retarded, like my dad, who suggested putting no nails on the strip to get it back on...
its hardly retarded, the only other way of putting it back on is to have used screws.
vw used glue to hold them on in the first place didnt they?
as above a petrol soaked rag and plastic scraper will do the job.
Its the glue that he used to do it before thats annoyed me, I have got everything off fine and after some elbow grease I have got everything apart from that glue off and looking alot better
