Heater fan motor stopped working
Heater fan motor has stopped working and blown fuse it was making a clicking noise for little bit i know what's does anyone know how hard they are to change in a polo 6n
  • Views 879
Removing
– Open air duct cover to side. – Pull connector -1- off series resistor.post-36925-0-45585700-1398098126_thumb.p – Release retainer -3- then turn fresh air blower -2- in -direction of arrow- and remove.
Remove the trim under the glovebox then you'll see the fan unit, there is a thermal fuse in the resistor pack that should trip if it gets too hot but as you've blown the main fuse, it's probably a siezed fan/motor
