changing clock clusters
hi all
I've got a polo 6n2 14 16v on a w reg and I'm looking to change the clocks ie rev counter and speedometer, i wanna put the gti clocks in, personal choice.
just wondered if any one could help and is the plugs on the back the same line up as well as everything else.
thanks and look forward to hearing from you all :sorry:
  • Views 907
First Welcome to the forum.
The GTi speedo will just plug in (same connectors) only thing you'll be missing is the outside air temp display unless you fit and wire the sensor behind the bumper
you will also need the black trim piece as the gti one has an extra analogue clock in the middle.
