Recommend silver spray paint for steel wheels please
I have a set of 13" steel wheels off mk2f and I want to sand and treat rust etc and spray silver with rattle cans , can you recommend a brand please also would like to clear coat after sliver has been done ..will also need undercoat as might take back to bare metal..
Edited by 1vw2many
  • Views 1.8k
Wow fast reply , works out quite expensive but good stuff does :smile:
yeah that should make for a good long lasting job
if budget is tight then you could always use silver metal paint, its designed to be put over bare metal and hold up in bad whether.
i have used this a few times on the insides of wheels (so the inside faces when you turn the wheel upside down) and it very rarely comes up even after thousands of miles. i have brushed it on but usually spray it. if brushed it will leave brush marks, but i sand it down once its cured and it looks fine.
this sounds a bit ghetto, but it works and will look good if its preped right.
eaither way you go, you will need to sand through any rush until its completely gone. it there is curb rash then again sand it flat as best you can. ideally tyres off, but if you need to get into the edges of the rim then deflate it and push something line electrical cord under the edge between the tyre and rim. then once its all flattened , use a solvent cleaner such as white spirit, panel wipe etc to clean it and let it dry then a coat or two of primer. let it dry then a few color coats and then a few clear. dont try to sand the colour coat and it will show up in the cler, if there is something wrong then let it dry complete before sanding, then redo it. let it dry then pull the cord out and reinflate.
if you do plan on wet sanding them then leave them for at least a day to fully cure.
Thank you have use zinc182 before on bare metal as primer but have run out :-( like the wire idea .. Thanks
Try spraying the wheels with two pack primer and then spray with clear lacquer
Two pack have not got correct breathing mask for two pack
