Duostyling AFRM Gauge - Fits Mk3 Dash Blank
Good overall condition,
used to have this fitted to my Polo GT
V simple, + & - wires (I had these wired up to the cigarette lighter loom) and a signal wire which goes to the Lambda sensor and gets tapped into one of the wires there (can't tell you which one, whichever one is the signal wire to the ECU I guess).
The signal wire will need extending, heatshrink and a soldering iron would be ideal i'd have thought.
£35 posted
  • Views 252
Would this work with my bike carbs? I have no ecu so no power to the lambda but I still have the wires going down to the lambda sensor to wire to?
Hi there,
Not sure myself, it'll be best off asking in the engine forum and going from there.
You could easily connect your lambda to a switched ignition source if necessary?
I'll take this Martin, I know they aren't a patch on wideband stuff but are cool and retro :)
Can you pm me your paypal email.
Cheers mate.
This item/s has now sold.
