GT G40 SPI MK3 Shed Clear out Hoarding sucks
B1288913-4205-49FF-9E64-52E9E01EE37D_zps
CC628417-2971-44B6-893B-6F5844C88B7D_zps
4C99F178-A152-4C34-8E44-C6D594FE6196_zps
2DB2DA37-7D35-49B1-A39E-6063CF62E186_zps
5ED8165E-D4D8-4623-A79A-8F94310208AC_zps
F288F4E6-16BF-4CE9-A86E-3C15CD026BBD_zps
84DF5E77-6322-4B18-B268-881ACEE03E18_zps
1 x G40/GT steering wheel.....................................................20
Badgeless grill ( 1 clip left)......................................................5
GT clocks 77k.......................................................................25
SPI clocks 154k ish................................................................10
RMD Gauges - boost psi,oil pressure bar, oil temp........................10 each
TIM boost Gauge bar.............................................................10
Narrow Band lambda (painted black bezzle not the best)..............15
G40 Alternator.....................................................................20
1.0 SPI Ecu.........................................................................10
1.3 SPI Ecu.........................................................................20
Late Spec Lights (Each one cracked).......................................15
3rd Brake Light (plus wires)....................................................15
G40 Carbon Canister.............................................................10
Non Thermo Sandwich plate...................................................25
57mm Boost t with Bailey Dump Valve......................................35
Random Small washer bottle with pump....................................10
Black sunvisors....................................................................10
GT rail and injectors.............................................................20
Fan cover and boost pipe......................................................15
G40 Charger elbow...............................................................25
Oil Catch tank.....................................................................15
Charger hard oil hose............................................................10
Chrome handles (1 lock delete, both need tlc)...........................10
mk2 G40 Throttle body(idle switch needs replacing.....................45
mk2 golf 5 speed leather gear knob.........................................10
Shitty centres (someones painted black in the past but they are peeling 10
2 x G40 3 speed fans and shrouds....................................................20 each
G40 inline pump.................................................................................25
All items Located in Barrow in Furness or Sheffield this weekend!
Price is negotiable postage and paypal fees on top mofos
Edited by etches69
  • Replies 9
  • Views 607
how much for the tail lights with the smoked indicator lenses
Price is next to all items, ill pm you a price to your door
Would you take £25 posted for the best of the two wheels?
1 G40 wheel sold
RMD Boost and Oil Pressure sold
g40 alternator sold
pmd
G40 Inline Fuel Pump £25
2 x 3 speed Fans and Shrouds available £20 each
Loads of other bits too
G40 Inline pump and catch can sold
GT Clocks Sold
Would you sell the boost t piece without the dump valve?
Pmd
