Fixing whistling air vents.
Ever since i bought my car the air-vents have whistled as i drive even with all the switches off. So not long ago i was putting the dash back in and saw the vents and thought "how do those come apart" as a result i became distracted and the dash got left on the front seats, the result would be the most interesting and amazing guide on club polo . . . how to stop those interior vents from leaking air.
So first of all remove vent. Many will know how i imagine but just incase there is a screw behind the vent that you can undo by putting a screw driver through. Or it will come out anyway because someone already broke the plastic said screw goes into. Then you will have this . . .
First of all the plastic lever bit (technical term) needs to come off, if like mine then it will resist, i levered with a screw driver but you might risk breaking.
After this you need to remove plastic inside, i found it easiest to press on the top and bottom of the casing while pulling the plastic bit out.
Inside the groove there will be that hidious perished foam that will need to be cleaned out.
Then get a strip of foam that's long enough to go round all four sides and then add glue into the grooves. Then put the foam in best you can and then work round all sides with a flat blade screw driver to finnish off.
Next trim the the foam, better to not trim enough than too much.
Now put everything back together, see how it works, if it doesn't turn too easy then take back out and trim more foam, the sides need more off than the top and bottom.
And there you go, interesting stuff i know.
  • Views 3.3k
hehe i did my golf same set up ....one tip that might be a bit neater , get a sheet of 2mm foam stuff from the craft shop and cut a big O shape that matches the flap shape
dunno how the mk2 polo vents come out do you? wouldnt mind fixing that
Yeah would be better to be a complete shape rather than two joining ends, i'm cheap though. I used trimfix from a spray can too wich was a bit messy, would be better to spray some in the lid and brush the stuff on.
Considering your picture i pressume you're asking about pre 90s and i haven't owned any to be honest, have a manual for one though but it doesn't seem to mention how just has a diagram of the whole heater/airvent system and that just shows two spring clips on the left and right of the vents. Worth putting a torch through the vent and checking for a screw behind but otherwise maybe it just pulls out?
Edited by joe420
yeah like my piccy ...I've had a poke round and cant see how they come out
have to have a better look another day
I know what I'm doing this weekend thanks Bro.
Neat trick there,i dont have the vent whistle on my new polo but drove me mad on the last one,handy to know in the future
FAQ?
I'll be doing this soon, Great guide! :smile:
