Undersealing polo.
Hi guys, am looking into undersealing my car, but looking under the car properly it doesn't look to bad, I have bought the Hammerite underseal product but I am just wanting to know if you guys think I is werth touching etc. some advice would be great. Cheers people
  • Views 1k
my opinion- no
most rust will start where the factory applied sealer has cracked , this goes on for years until the rust shows past the thick sealant
painting on thick gloop will just hide it for longer
what i would do is - once a year or so give it a good jet wash and then check carefully with a good torch for any suspsect looking brown bits , scrap them back to bare metal with a old wood chisel then clean up with a wire wheel in a drill , etch or epoxy primer and then some seam sealer and /or gloss paint over it
that way any fresh scabs are easy to spot and dont lay festering for years and get into rust holes
+2
...and again!
Underseal is brilliant for holding water next to the bodywork - exactly where you don't want it!! The problem is that the water gets in (as it always does) and then can't get out - result - sealed in rust.
Regards
I undersealed my car. Use bilt hamber stuff. Its amazing. It will repel moisture and spread inside all the cracks. Its worth it but 99 percent of the job is the prep
Fs! Makes me regret underselling the whole underside of mind with one of the proper spray guns :/
