Help identifying my first Polo :)
Hi all,
I've just bought my first Polo, I needed a more economical car to get to work, and an older polo seemed like the best choice as I like German cars :)
I'm not sure what the power is and I don't fetch it until tomorrow, so I wonder if you guys can help?
It's a metallic blue 1.4 16v in a sporty trim with alloys. It has air con, it's 5 door and has 16v badges on both the front grill and boot.
Is it 75bhp do you think?
Looks the same as this one, same wheels and everything
http://www.germancarbreakers.com/ekmps/shops/lbtrading/images/2001-volkswagen-polo-mk5-6n2-1.4-16v-sport-720-p.jpg
  • Replies 11
  • Views 784
Its refered to as a 6n2 on here, its most likely going to be the 75bhp or it could be the rare 100bhp model, try get the engine code up
Thanks for that, hoping to collect it tonight so I'll check the engine code and update the thread.
Cheers buddy
Another thing I meant to ask is about the clutch...
It's not heavy or stiff (I read a bit about the pedal box), but the biting point is really high, is this fairly normal on these cars? It didn't slip at all, and changed up and down smoothly.
Is it self adjusting or can I change the biting point?
Can change the biting point via the cable on the gearbox, high biting point would usually suggest the clutch is well worn. But worth seeing if you can adjust the cable anymore to get a bit more life out of it
Cheers Matt I'll have a look this weekend
100bhp.
It's an AUB??
AUB is the 100hp
AUB is the 100hp
Oh cool, nice bonus then. Seems to run well enough, can't make out whether there's a slight blow near the front or whether they do sound a little bit sporty? It's a totally standard car, only done 60k, interior is spotless, but few dings around the body, nothing horrific mind.
One of the rarer polos these.
Seems pretty nice for an older motor, certainly feels nice and solid, still unsure of the clutch but we'll see. Don't mind spending a few quid on it if it's going to be good little motor
Cheers mate
