Floor insulation mk2
I've stripped my interior to clean it all up properly but all the insulation is ruined what's people used and how much will I need would someone send me a link? Thank you
Rob
  • Views 655
If you google it you can buy the stuff but personally i'd go to a scrap yard and start ripping up floors and then cut it all to fit the car but that's cause i'm cheap.
I did the same when the car had a water leak. Took the interior out of the car and found the under felt was beyond saving. Went on line to find replacement but proved far too expensive. Went to a local carpet shop and asked if they had any off cuts of good quality under felt. Bought a great piece enough for 10 for £5. Did a brilliant job. You would not know the difference.
