12v cigarette socket wont work
Hi guys n girls.
So in my other car my VW caddy my cigarette lighter socket won't work i know it's not the fuse as i have checked already also my cigarette lighter socket in the back seat also works.
any ideas?
cheers
  • Views 1.5k
I have this same problem in my 6n2. Rear works, front doesn't.
Is it an easy part to remove to repair/change?
Try the correct forum, you may get a better response.
It's pretty simple really.
Is there a live feed to it? Should have thought it will be feed with the ignition on.
Is there an earth to it?
Check it with a test lamp.
Is the fuse okay?
If yes to the above it's fucked.
I'd imagine it'll just pop out with the help of a friendly flat head screw driver, or Gary as I call mine.
