Early 085 (Pre 6n) 1-2nd gear syncro hub
I'm after an early synchro hub for my ATV box, appears to be used on all five speeds up to the 6n era where the number of engagement teeth changed. Hit me up with what you have.
Edit: will take a broken box if anyone has an early one lying about, unloved.
Edited by Vic
  • Replies 10
  • Views 216
Will be stripping a box soon - I only need the bellhousing
Where are you?
Thanks for replying, i'm in the midlands - Daventry although happy to pay for postage.
Cool.
I'll hopefully have the box apart within a week if that suits you.
That's brilliant, I'm in no rush (as always) so thanks a lot.
Thanks for the vagcat picture, its item 22. It consists of a sliding part with an outer gear for reverse, and an inner part with three keys, two springs which is pressed onto the actual shaft. I'll take the whole shaft if you don't have a puller.
My mate did a scrap run the other day and took the gearbox, under the impression I'd done with it after I'd removed the bellhousing!
Sorry :(
No problem at all, there's plenty more broken 085's out there to raid!
I have a broken 085 box, think its either a CEG or CEK, I'll check.
Can bring to the Polo Show if you want it?
I'll check that it has the early synchro's on vagcat, but that sounds perfect - thank you..
