Change rear windows mk2 how ?
Does anyone know easiest way to get them out and back in both sides?
  • Replies 8
  • Views 861
  • steveo3002
    steveo3002
    use a flat blade screwdriver from inside to ease the rubber over the metal lip on the bodywork...work all the way around and the glass lifts out for re fitting fit a thin rope into that gap on the
for re fitting
fit a thin rope into that gap on the rubber where the metal lip was ...get a help to hold the glass against the opening while you sit inside and pull the rope , it should pull the rubber over the metal lip
once its in give the glass a a gentle thump all the way around with the botton of your fist to seat the glass
Legend will be given this ago when my new glass comes :D
side ones go back fairly easy ..but if you feel the need for lube then sex lube is ideal , safe for rubber lol and slippy as hell
you do get some funny looks buying rope and king size jar of sex lube though
Edited by steveo3002
Method 1:
for re fitting
Method 2:
Lay on the back seat and boot them out. Get a mate to catch them. Refit with a rubber mallet.
Method 2 is not without it's risks, but it is generally much faster.
Lmao sex lube and rope may be awkward purchases!
get some cucumbers and gaffer tape to make it look more innocent lol
Lmao and a big apple
