Mk2 speedo error
Hi all, Recently noticed my speedo is reading around 10-15mph above actual speed (GPS) and its been bugging me for ages as to why this is..
I have 155/55/r14s on a mk2 coupe and i expect the speedo to read slightly off but not this much..
I've put it down to the spring? behind the speedo needle.. seems to be common with mk1 and 2 golfs, speedo takes ages to come down when your at a standstill too.
Does anyone know if the spring can be replaced or if theres a fix for this? If not i'll just buy some new clocks but will need to wind the mileage back which brings me onto my next question.. does anyone know how to do this? and if done will it affect the rate the milage goes up in the future? heard some stories of once they're wound back the miles seem to rack up alot quicker!
Thanks in advance
  • Views 713
I found a similar issue with a set of mk3 clocks I had. Mk2 may be different but it may help...
I cracked them open and noticed the needle had been removed at some point, when it was put back on it was just placed on in the rest position. This made for the same effect that you are noticing with your speedo.
What I did was place the needle lightly on in the rest position and turn the spring with my finger until the needle was at 10mph, I then moved the needle down to rest on the stop and pushed it fully home.
You may need a bit of fine tuning depending on your tyre size etc. but for me that worked a treat and I've got quite an accurate speedo now.
