hot air and oil smell in vents
I have no cold air in mar car or it'll be slightly cold for a second then be warm and will smell of an oil type smell. I have a new cabin filter so I'm pretty sure it wont be this. what else could this be?
thanks.
  • Views 2k
Oily smells can sometimes be caused by the crankcase breather system, check the hoses that vent from the crankcase to the air cleaner assembly for splits.
Thanks for the reply but sorry but what is this? I have no idea, any pictures of it? Thanks.
post-36925-0-18063400-1400661441_thumb.p
Pipe #5 goes down to a box on the back of the engine under the inlet manifold.
Check the pipe is connected at both ends and there are no splits/cracks in the pipe
Here's the list of part numbers depending on what engine code you have?
breather hose
/ AER,ALL,AEX, ANX,APQ,AKV, AEE,AHS
breather hose
/ AFH
breather hose / F >> 6N-XY356 746*
/ AJV
breather hose / F 6N-XY356 747>>*
but with: / AJV
28B 030103491
breather hose
/ AER,ALL
breather hose
/ AER,ALL
I don't have my standard filter pipes on as I have a cone filter. I do have a small filter on the end of pipe #5 however it does have a yellow gunge type substance around it, could that be what's making the smell?
Thanks.
I would say its likely, the little filter keeps the oil droplets from escaping but you'll still get smelly fumes out of there. Try diverting it under the car to avoid filling up the bay with fumes.
Ok, thanks. I will give that a try as well as checking for leaks in the pipe.
I reattached the pipi to the old air box and the smell has gone. The air is quite cold any way to get colder air without air con?
