Boot Problem - Handle not opening from the outside.
Hi all,
Hope someone can help.
In short, my boot fails to open from the outside. I feel no kind of resistance / click at all when I pull the handle.
I've managed to open it from the inside by pulling the lower 'metal pipe thingy maboby'. But looking at it I can't see anything obviously missing / damaged (Not that I've paid much attention to the lock mechanism before).
Just wondering if anyone can help me out? Anyone have a good diagram of the entire mechanism at all?
See pics.
Hard for me to point this out because I'm not very technical with this stuff... But it looks like 2x hooks one under the other. I'm when I pull on the handle the one on the top (Yellow) goes down. The one under that (Brass?) does not make any contact with it... I assume this should be the case to enable the boot is release? I don't fancy getting a replacement part because it seems to contain way to many little fiddly bits for my liking.
again, If anyone could help me out then I would really apprectiate it. Failing that, I'll plod on and try to figure out some good bodge job for it!
Thanks in advance.
Liam
It looks like the C/locking actuator could still in the lock position,?
oooops, sorry, forgot to mention that. when I press the central locking button the actuator freely moves up and down.
Is there any posibility that the lock cylinder has been replaced?
◆ When changing the lock cylinder, be careful that the actuating pin -13 - does not get lost. If the pin is missing, central locking will not function
post-36925-0-16056800-1400700285_thumb.p
The other thing I seem to recall with the lock/key is there is three positions and one of them effectively locked the boot shut and even the C/locking would'nt release it??.
hmmmmmmm thanks for that. I will have a little look. It's odd I've owned the car for a fair few years now and have never used the key to open the boot. will have a little play with it tomorrow / weekend.
looking at the picture, the actuator, then the white bit with the coil. the white plastic does seem to be holding the one arm and thus bringing the brass hook down avoiding contact with the yellow handle hook to flip the metal stripe / pipe if you know what I mean?
Thanks for your help. Much appreciated.
Liam
Fixed! Just incase it helps anyone. Again. I fon't know all of the technical terms... I followed the back of the brass hook anf felt a leaver. Gave it a quick tug and it released its self! Saweet!
thanks
Liam
