radio removal problem
Hey guys i am new here :)
So heres the issue i bought my polo with a after market pop out screen problem is the face doesnt come off so i want to change it for one that does
So i took 3 of tge tiny screws out but the 4th is rounded off how can i get such a small screw out thank you
  • Views 821
a photo would help. I think you might just be unscrewing the screen.
The screen is tucked away the unit is held in by four screws and one is rounded o cant get it out
I will get a photo tho
Drill the head off
try using a dremill with a thin cutting disk to make a small indent into the head of the screw, then use a flat head screwdriver on it, if this fails jus drill it out
