Wiring help
  • Views 617
The two Brown/White are Grounds
Blue is the feed to the ECU
Yellow is the feed to the temp gauge
thanks....if you don't no what I am doing I am cutting most of the loom out for racing......
sorry when you say yellow its actually yellow/red
so if I ground out the 2 brown/wht wires cut the yellow out and leave the blue it should be ok.....yes
I suppose the blue wire tells the ecu that the engine is still cold and it need more fuel ???
there is another green temp sender with a single blue wire on that end of the head,,,what is that for ??
Edited by bobsp5
I could only see it as yellow,but yes it's yell/red to the gauge.
The blue wire to the ecu is for the fuelling schedule at the varying engine temps, and if you ground the two brn/wht all should be good
The other sensor, is it in the thermostat housing or on the head? I can't recall what engine you were using?
1.4 16v AFH engine
Should the red/yellow wire be joined to a live
The other sensor is green,has a single blue wire and is on the front RHS of the head ......thanks
Edited by bobsp5
Low oil pressure switch
AFH Wiring Routing.doc
