Best way to spray
What's best way to re spray the plastics for the centre console
  • Views 997
Cheers man what about sanding them down?
It's probably better to sand them down helps the paint stick. The parts I sanded down felt all rough though, didn't use high enough grit sand paper.
degrease the part several times as its probably had alot of dash sprays on it over the years
key it with a grey scotch pad ...just need to scuff it dont go mad
plastic primer x 2 coats
sand with 800 wet
paint with colour of your choice
Thank much appreciated
Thanks much appreciated
I cheated and used plasti dip.. No need to do anything other than clean and spray. Hard to mess it up. Standard is matt finish. But you can also buy glossyfier if you need too...
And!!! If you ever want to get rid you peel it off
