Steering wheel has "up down" play
My steering wheel / column has some play in it, like the column isn't secured properly. I can sometimes feel it jn the brake pedal if i steer, and if I pull on the wheel while sat in the seat there's about 6mm play. Anyone else experienced this? Any remedies? .
  • Views 722
the adjuster bolt will be loose, it happens over time.
You mean the bolt associated with the height adjustment? or the bolt at the pedal box?
Edited by pjw
This is now solved, it was the shear bolt that holds the ignition barrel onto the steering column. Little brass thing, had worked its way loose ish. Managed to remove it using mole grips een though it should nave been drilled out.
Replaced it with a standard m8 25mm bolt, no more play.
Turns out the column is standard in mk3 golf's and this is a common problem.
