newbie
hello all
i've just bought my first car (16yrs old)
its a white mk2f
1272cc
it looks tatty but my dad has stripped the interior out and jet washed it :puke::puke::puke:
the bodywork is 80% good a few dints and the boot lid is rusted in the corner
my plan is a
4 branch s/steel exhaust
cbr 600 carb conversion ;info needed
poly bushes
-80mm supension kit
front brake upgrade ;info needed
rear disc conversion ; info needed
i have allready bought some 15"bbs split rims which we will split dip and refinish new bolts
and when i get the money a re-spray
my dad will do most of the work he has done up a few cars
his latest passat
i need to read up on carb fitting and brake conversions
cheers
Haiden
  • Views 472
Welcome along!
Lovely looking passat!! Spend some time having a search through the FAQ's and technical sections as all info you will need will almost certainly have been covered before, if not post up in the relevant section
i am looking for a fitting guide for the carbs the are a lot of pipes and electrics behind the rocker
whaat do ikeep what do i blank ????
i've loockd through alot of the forum about it ,fuel/pumps regulator t peice etc
just wanted a fitting guide with pics
cheers
haiden
