Best way to remove rubber top coat?
How to prep the centre console ready for a respray?
  • Views 803
Popular Days
What car is this?
I'm guessing it's 9n, as it has a rubbery texture. I would use paint thinners and a rag. It should come off easily. Then key the surface with a scotch brute etc and thensome adhesion promoter (plastics primer) then you could use another primer over the top depending on colour, or go straight over with oak t. Depends what colour and finish your after really but plastic primer is a must because the paint will just flake off after a while.
