Bucket seats, where do i start?
Hi, I am after some bucket seats to fit my 6n. I have some subaru ones but obviously they do not fit in with modification.
Basically the reason for this topic is for those who have or had bucket seats in a 6n and how do you get them to fit or is there any bucket that fit straight in?
Thanks for your time.
  • Views 850
Did you mean to say that your Subaru seats will not fit in WITHOUT modification? Or, have you carried out some other mod which now precludes them?
I have left this item for a few days in case someone has first hand experience of this subject, but as there have been no replies, I would suggest the following.
Check that your Subaru seats are physically the right dimensions (its no goo if they won't fit in the space available.)
Remove one of your 6 N seats, tip it upside down and compare the underside with the seat from the Subaru - It may be possible to devise/fabricate some mountings that will allow them to be used.
like yourself, I am a West Yorkshire lad, who hates wasting things!
Regards
How do the Subaru seats mount are they on runners?
A conventional bucket seat can be either side mounted or from underneath. Which is far easier then making other seats fit.
However if u can weld and have an idea of fabrication I would suggest removing your 6n seat or find another and remove all the padding and and cover from it leaving u with just a metal base that fits your runners you don't need the back just the bottom. Then do the same with the Subaru seat making sure u don't damage it as it will need to go back together so know u should have two bare bases and need to combine the two keeping the support and all the bits need to put the padding and covers back on and keep it reclinable.
If u don't feel up to it don't bother.
