Oil light - sneaky fix
So my oil light used to come on now and then.. And every time I checked the oil levels and it was fine.
Anyway after a long drive up to fort William, it became permanent, and after ring rejected from a garage my mate was talking to another mechanic who said to pull out the bonnet latch sensor under the bonnet and put and piece of wire joining the plug short circuiting it. Oil light went off! It seems to be a weird thing that some people know and some don't. Car did and has been running perfect as well. Covered 200 miles with te light on and not a single problem!
Happy me.
Edited by Guest
  • Replies 12
  • Views 1.5k
How about actually fixing the problem, such as fitting new switch or checking the oil pressure?
I hope you are thinking about fitting an oil pressure gauge to keep an eye on the pressure manually then?
As if the engine does loose oil pressure as you're driving along then you won't be driving it much further.
According to this guy it's just this sensor that messes things up. Although I wouldn't mind checking the pressure depends on money time etc.
And come to think of it, everytime it came on I open and shut the bonnet, from which it went on afterwords.
I'm not short circuiting out the oil sensor, it's one under the bonnet that can affect the oil sensor. If it's 3 beeps when the light comes on it's oil pressure, this never happened. Gonna get the sensor though, use vagcom etc.
All good fun until you end up with an oil starved head and no idea is happening.
The sender doesn't tell you they'd oil in the sump, that's what the dipstick does, it tells you there's pressurised oil reaching the top end.
Yes but the bonnet sensor is wired to the same light as the oil light, if it was the oil pressure the light would have come back on not just go off. Surely 250 miles now would have killed it if has been running low on pressure?
I think the best way to find out is buy a new oil and bonnet latch sensor, and try them and see if the light comes back on.
Edited by Guest
You haven't said what car this is on, but I guess you mean you've earthed out the oil level sensor. Providing your car has one.
Again another potentially bad move as if your engine suddenly develops an oil leak, you may not know about it until it is too late.
Obviously religious checking of oil etc. will mean that isn't an issue. But are you sure that the level sensor doesn't effect the performance of the pressure sensor? Are you sure its a level sensor?
If it were me I'd get the suspected sensors changed and even temporarily hook up an oil pressure gauge for peace of mind. You can buy cheaps sets off ebay for £30 that give you the sender and the gauge with instructions on how to fit.
It's a 1.4 tdi 2002 9n sorry derp lol.
No I've earthed the bonnet latch sensor, so if the car was on with out the bonnet closed a light would come on. And I've been told the oil light comes on when this happens.
I didn't know these had an bonnet open light, I never heard of one.
Sorry, it's an alarm not a sensor? Sorry if I've made this hard to understand I just don't know that muh.
Anyway this is the alarm in the Haynes manual.
And here is what I did (piece of wire joining the plug shorting it)
New oil switch and pressure gauge is on it's way anyway, just wanna keep an eye on it.
And check your wiring isn't worn or damaged.
250 miles with poor oil pressure probably won't hurt, but if longer term you're taking chances with your turbo unit as well as speeding up wear on the cam and followers.
