Treating rust patches
Hi people, not very experienced with repairing cars but I'm looking to try and repair the rusty areas on my mk3 polo, such as the wheel arches, bottom of door and inside my boot ect :/ I'm guessing I could spend a lot of money on it but I was wondering if anyone can recommend a simple but effective way of doing it without costing a bomb, e.g filler, fibreglass? Not got a clue as you can see so any advice is appreciated!
Welcome to the club
The bottom line is you need to get as much of the rust out as you can. Covering it with filler or paint will patch it up but in the long term the rust will still build up underneath (hidden) and when it reappears it will be much worse.
To treat surface rust on my project I've even using wire wheels and a flap wheel on a grinder then using 3 stage POR 15 paint which seems to be held in very high regard. Have a look on my thread, I think there is a photo of my bootlid which I did this way.
There is no real substitute for cutting out and welding in new metal on larger patches though.
There's lots of resource on here if you search, also just searching online is a great idea too.
For small areas;
Depends how bad it is.
If its just surface rust then;
Scrape away as much as possible with a screwdriver, go as far around the area as needed. You may need to chip away some paint.
Treat with rust killer.
Paint a few coats.
Large areas then the panel would ideally need respraying and cut out as said above.
theres no simple brush on cure
wire wheel , dremel , sandpaper , snadblast until its as clean as possible - not just a quick wipe over it needs to be silver metal again
then some good primer of your choice..i dont like por15 myself , i would go with jotun expoy primer or a good zinc primer , then top coat
if its holes then it needs a new panel or a patch welding in
