Removing standard tow eye.. fitting after market benen one
I was planning on removing my rear tow eye just now expecting to see it bolted to the body but its not :( I have a beautiful! benen tow hook that has two holes for two bolts at the end.
Am I going to have to cut the standard one off then bolts the new one on? Or are there hidden bolts somewhere?!
thanks.
  • Replies 8
  • Views 945
  • Don't forget you also need to put a massive "illest" sticker on your windscreen, stickerbomb a wing and paint your steel wheels odd colours for it to work :rolleyes:
The standard rear one is welded to the floor pan as I recall??
Brilliant.. That means cutting it off. I got the spanners out, got under the car and couldn't find any bolts, not best pleased.
Thanks.
Does it not come with a clamp? Tow hook one side of the original eye, clamp at the other side, bolts through till tight? That's how my benen was on my civic
Ahhh yes! I though that was to adjust the angle of it! I will have a look I still wouldn't mind getting rid of the standard one though it is quite unsightly.
That didn't work... Not able to bolt it on with the clamp. *If I cut the old one off, where's the best place to bolt the new one on to?
Haha next on the list ;)Thanks..
best place to bolt it to would be where the standard one was welded to?
