aub engine code what gearbox will fit
As title 1.4 16v 100bhp code aub what gearbox codes will fit thought the one off my afk would but it's slightly different and starter is different too ?
  • Replies 11
  • Views 3.2k
That's odd as Elsawin lists exactly the same codes for the AFK as the AUB all are 085C here's the list DXJ, DXM, ETB, ETC, FFL, FFM, FHX, FHZ
The flywheel on the aub is slightly bigger
It's the same part number for both engine codes and both use the same 200mm clutch!
IMAG1044_zps8nhnbqqd.jpg. IMAG1050_zpsxf8h7ni8.jpg. IMAG1055_zpsr6mnjfof.jpg. IMAG1042_zps8jpqnkeg.jpg
The clutch and. P plate are the same on both but they are different flywheels
Well in the parts listing there is only one flywheel listed and only one starter ring gear !!!
Someone said the aub engine came from a 9n polo could this be why I'm struggling to find the Wright box ?
02t ??
If the AUB did come from a 9N then it would be the 02T box
Any idea on codes for the 02t boxes to suit the 1.4 don't want to end up with a 1.0 box lol
These are the codes listed for the AUB in the 9N FCV, FQE, FVS, GDG, GEM, but the 02T uses a hydraulic clutch, so you'd have problems fitting it into the 6N2?
