buying a coupe with no keys. help needed.
Hi all i own a 6n but fancy a project, I'm a bit of a newbie to coupes, had one before but only for a few weeks due to engine issues.
Now, I'm buying a 92 1.3 coupe But owner has lost the key so its been sitting a few years. Basically i need to get into the car so i can load it onto a recovery truck and then move it into my garage. I would rather not smash a window or cause damage to the steering lock off so that i can move it. If someone could pm me some solutions i would be very grateful.
  • Views 760
If you're winching it on, no need to get inside really. Just jack it up, unhook the handbrake cable if it's on and work the gear linkage to put it in neutral.
If you can drop a lock barrel out of the door, a decent locksmith should be able to cut a key to match it.
Better if we don't talk about how to break into a Polo on a Polo forum. No doubt someone will PM you a few ways, it ain't hard. If you end up doing a window, the front quarter lights are easiest to replace.
And if any of your mates have got old VWs, try their keys, it's amazing how often it works!
Ah ok thanks for the advice wasnt sure whether to post about it or not. Yes I have a few mates with mk3's so will give their keys a try. How much roughly do you think a replacement key would cost to have cut? If I were to do the quarter light would a new one just pop in or are they held in by screws or anything? Thanks again.
The place I use doesn't charge much at all for how long they were fettling with it. The best bet is find an old boy with a key cutting stall on a market, a proper automotive locksmith will probably charge a fair bit more.
Front quarter glass is easy to change. Wind the window down, take the door card off and the bar between the drop glass and the quarter is held in with one screw down from the top, and one that you'll see behind the door card. Give the bar a little wiggle and take it out, then the quarter glass just slides in and out.
Just phone a locksmith and get a key cut,
Your going to have to do this anyway so pay the call out charge it will save you having to repair any damage braking in.
If you do pop the front quarter you will have to strop the door to replace the glass its far far easier to replace the rear window as its just rubber'd in.
There not particularly hard to break in to if the keys are lost I've broken into many new cars where owners have lost or locked keys inside. It's funny you can actually buy a kit to break into car it has lots of rods flat strip of metal with shaped ends so u can pull the linkage. If u want to know a seriously easy way pm and u will be in the car in seconds.
Just saying I'm a mechanic and have never gained excess to a car without owner permission.
Ok, thanks guys for the help. Much appreciated.
If its a mk3 giving it a dodgy look should be enough to open it.
