For OFFer/help Mk2 coupe S
Hello everyone.
I have for amny years had a Mk 2 Polo Coupe S
Its been through 1 bottom end (set of dodgy rings, when i replaced the worn out set at 140k)
Unfortunately last week whilst out and about the rear trailing arm sheared through a rusty patch, and has resulted in a very negatively cambered rear offside wheel.
I loved this car, as it was cheap, very ecconomical (45+MPG) and great fun to drive. Unfortunately i have been unable to track down the bits i would need to repair it : A rear trailing arm, fuel tank (my filer pipe is leaking) and some time to fix it up, repair some of the normal rusty patches, and get it back into good shape.
I am looking for anyone who knows where i may be able to source a rear trailing arm, that won't be as rusty as mine was (its way too rusty to weld!) for relatively cheap.
Alternatively if there is anyone out there, who would like the car, make me an offer. It was running sweet as untill that point, and if i have to get rid of it, i would rather it went to someone who knows, cares about and likes Vdubs rather thena scrappy.
Thanks for looking
Scott
  • Views 860
Can you find an old mk2 or mk3 that's being broken on ebay or something similar?
The trailing arm and rear beam are one unit, so you will have to replace the whole rear beam. It's not such a scary job, but get the car supported nice and high up and get a mate or two to help you because they are heavy. You should be able to find someone in the cars breaking section who can sort you out with a rear beam.
The good news is, if you're taking the rear beam off anyway, it makes changing the tank loads easier. I think they're about £60 for a pattern part, so long as it's a lte mk2, early ones are a bit trickier, but do spend a bit of extra time and money giving it a thick coat of rust-resistant paint, or you'll be doing it again in three years.
I will have a rear beam coming up soon as I've just managed to get a g40 one.
I'm located near Harrogate but can probably post if needed!
Cheers for the advice guys. I'd come on here after having no luck on ebay, or any of my local breakers yards (Bristol, or Chichester where the car is...)
If I get an arm, I'll probably do the tank too. and yes plenty of rust resistant paint :-)
Jakwadd, cheers for the offer i'll bear it in mind
