Squeaky windows!
How can I stop my windows squeaking when I wind them down. Its not the handle its the actual window on the seal I think. I've tried WD40 as this usually fixes everything.. But to no avail.
any ideas?
  • Replies 8
Vaseline ?
Hmmm didn't think of that! I will try it in a bit and let you know.
Vaseline didn't work.. I'm not 100% where its even coming from. Its not the handle, where else could it be? It sounds like the bottom seal..
It could be the plastic sliders on the mechanism, pop the door card off and you'll see the two metal strips that the sliders run up n down, put some grease on the these it might help also the plastic wheels the cable runs around grease them as well
Ok, thanks. How do I remove the door card?
it was the mechanism just needed a bit of wd40. thanks!
Mine are squeaking as well. I think it's just the heat to be honest they never usually do it and weren't tonight when it cooled down.
