angle grinding rear arches on polo coupe.
Has anyone ever done this.
I put my rims back on car with 5mm spacers and only the rear left side seems to be catching arch when going over uneven roads.
The rear right is ok.
I spoke to arch enemy but they refuse to do arch rolling on polo coupe due to the little holes on lip in which you would attach the black arch kit to.
Was looking into grinding the arches ever so slightly - simple enough to do? Anyone here done this?
Thanks.
  • Views 771
take a look and you will see spot welds all the way around the arch roughly in the center , you can cut off up to those leaving the welds intact
or cut most of the lip off including the welds and then have someone mig the 2 panels together to keep the strength
make sure its repainted well or it will rust like a good un
Hammer, block of wood - you'll need to repaint them though.
thanks guys!
if it is only scrubbing on one side, try re-aligning the rear axle first, there is a bit of adjustment on them.
