Got a dent....advice needed please
Hi All,
My son has received a dent on the nearside front wing just above the wheel arch on his Polo 9N 2007. I've had an expert dent remover look at it and have been told that although the dent could be improved but due to its close location to the wheel arch its not going to be perfect. This was also confirmed by another dent remover. The only solution is a new wing.
I used an online breakers service and a company called 247-traders.co.uk can offer me a new wing painted to match any colour for around £140.00 inc. delivery & VAT. I'll assume it'll be an OEM wing panel. Has anyone had any experience with this company and how easy it is to remove and refit a front wing?
Daz
Edited by dazzystar
  • Views 1k
I had a head from them on my old 6n and that was fine. If your getting a guarantee I wouldn't worry as if it's not up to scratch you send of back.
Wing should just be bolted on along too inside the bonnet, probably have to remove bumper to get to the from bolts and then bolted inner edge of door
cheers. Any online videos on how to change the wing you know of?
chances are it will be a pattern/copy wing not genuine , some dont fit 100% great either but generaly good enough
fitting is just a case of finding all the bolts ..once you have the new one you can see where they're located
