what model do I have
Hi guys and gals
I have recently bought a T reg Polo registred in 09 07 1999 with 3 doors its a 1.0L petrol
It does not have power steering or electric windows
the central locking is either nor working or not present ( I have looked for the vacuum pump on the boot and the recess its there but I cant find the pump maybe it was taken out)
Any help with the central looking would be great too :D
  • Views 723
You have a 6N1 or Mk4 on this forum.
The C/locking pump will be behind the carpet trim in the right side of the boot if it's fitted, but as you appear to have a low spec (no PAS or elec windows) you might not have C/Locking, if there is some plastic pipes and a connector in that area, the pump has been removed, if there is please make a new post in the electrical technical section
You got a 6N model mate. And as for Central locking can you see any loose wiring or a plastic tube laying there if not then most probably not got central locking but I might be incorrect.
Thanks for your help guys
Just went and checked and no wires or plastic pipes so defnitly the budget version
Less things to go wrong :smile:
thanks
I would agree with everything above. As for the central locking, go into the boot and open up the right hand side cover (my 6N has a First Aid kit sign on it and two turnable bits of plastic that allow easy access to this area. If you have a blue pipe and a power supply loose in there then you are missing the pump. If you have neither then the car almost certainly never had central locking.
If you are missing the pump, I actually have a spare that can be bought. I paid £45 for it recently from vwspares (their last one) in the hopes it would cure my own CL problems but sadly it did not. The pump wasn't my issue, instead it looks like a dodgy bit of pipe somewhere. Anyway... it means I have a spare pump for sale if anyone needs it.
Worth also checking under the carpet in the boot (where the spare wheel is) for a sticker that has lots of information regarding your car including the model, engine, paint colour and other things too. The sticker isn't always easy to see but it should be in there so have a good look.
