Chip under driver's door.
I noticed a paint chip under the driver's door and it is bugging me out! I want to know if it's possible to maybe fix this or at least make it less noticable. Thanks.
Photos:
  • Views 938
Popular Days
Deal with it before the rust sets in.
Before you do anything, get yourself a tin of the CORRECT colour paint, some primer paint, something like 'cureust' and some 'wet & dry' paper.
Providing that there isn't already any wide spread rust under the damage, just rub it down with a small piece of wet & dry, finishing with a fine grade.
Follow the instructions on the 'cureust' and then apply two or three coats of primer paint, allowing it to dry AND harden before applying the finish paint.
If the rest of the sill is OK, you may be better off applying the paint with a small (artists type) brush to such a small area, rather than masking up and spraying it.- If you do this, you will also need a small tin of thinners to clean the brush with.
Apply ONLY thin layers of paint at a time, allowing it to dry well between coats.
Allow the finished job to harden for about a week and then polish it in - you could use a piece of WELL WORN fine 'wet & dry' with some soap and water on it before polishing with compound.
If you don't have any compound, a little 'Brasso' on a soft cloth will do.
One word of warning - If the damage has been there for some time and there is rust at the back of the paint, you need to rub that down to bare metal before applying the 'curerust' (in spite of its name!)
Regards
